Article ID : 00123003 / Last Modified : 16/01/2026Print
    The time displayed on the "Setup complete!" screen of the initial setup is incorrect
    You can set the time by using CLOCK SETTING, an option displayed on the "Setup complete!" screen during the initial setup of Sony's Android TV.
    You can also set the time by going to the HOME menu and using the following path:
    1. Select Settings.
    2. Select Date & time in the SYSTEM PREFERENCES category.
    3. Set Automatic date & time to Off.
    4. Select Time.
    5. Select Set time and update the time.
