Can I use the microphone on a smartphone or tablet for the Voice Search function?
Yes, you can use the microphone of your mobile device for the voice/speech recognition with the following apps:
For Android™ mobile device
- Video & TV SideView app
NOTES:
The list of supported devices and OS versions is available on the Video & TV SideView Website.
Depending on the model of your TV, you may not be able to use the voice recognition function of Video & TV SideView.
In such cases, use the supplied remote control or the built-in MIC (only some models have a built-in MIC).
- Android TV™ Remote Control
NOTE: The information about the supported OS version is available on the Android TV Remote Control Website.
For iOS mobile device
- Android TV
NOTE: The information about the supported OS version is available on the Android TV Website.
*Android and Android TV are trademarks of Google LLC
