Article ID : 00118750 / Last Modified : 20/05/2015Print
    Can I delete the past play data from the Smart Tennis Sensor app?
    Yes. It is possible to delete the past play data from the Smart Tennis Sensor app.
    The play data is saved by date and you can delete play data for a specific day by following the steps below.
    1. Press and hold the tile of the date of the play data you want to delete.
    2. Press Delete.
