Article ID : 00159931 / Last Modified : 16/01/2026Print
    Can I download new apps to the My Apps area of the Blu-ray Disc Player?
    Each Blu-ray Disc® Player has a set amount of pre-installed applications. It is not possible to download new applications to your Blu-Ray Disc player.
    You can add or remove these pre-installed apps from the My Apps area of the Blu-ray Disc® Player.
    To add your favourite apps to the My Apps area, follow any of the methods below.
    Method 1
    1. While in the My Apps screen, press the UP ARROW or DOWN ARROW button on the supplied IR remote control to select the Plus (+) sign.
    2. In the All Apps screen, select the app you want to add.
    3. Press the ENTER button.
    Method 2
    1. On the supplied IR remote control, press the HOME button.
    2. Select the All Apps.
    4. In the All Apps screen, select the app you want to add.
    5. Press the OPTIONS button.
    6. Select Add to My Apps.
    To remove apps from the My Apps area, follow these steps:
    1. On the supplied IR remote control, press the OPTIONS button.
    2. In the My Apps area, select Remove Application to remove the app.
