Article ID : 00110725 / Last Modified : 12/07/2018
The Media Remote application will no longer be distributed on Google Play and App Store
On the 31st of March 2015, the Media Remote application will no longer be available for download from Google Play or the App Store.
If you already have the application downloaded on your Android or iOS device, you will still be able to use Media Remote, regardless of the app being removed from these two stores. You can select Open to download and use the TV SideView app or select Later to continue using the Media Remote app.
NOTE: Media Remote has been integrated into TV SideView. If you already had the app installed and wish to continue using it, please make sure you have the latest software installed on your device.
Media Remote integrated into TV SideView application
