Article ID : 00061160 / Last Modified : 21/10/2020Print
There is no battery charger in the box; it appears to be missing. Is one supplied?
    The camcorder is not supplied with a battery charger. The battery can be charged by connecting the camcorder to a computer with the supplied USB cable.
    NOTE: Make sure the computer is turned on to charge the battery in the camcorder. The battery does not charge if the computer is in hibernation or sleep mode.
