Article ID : 00126576 / Last Modified : 26/09/2022Print
There is no picture, or a black screen appears, when attempting to record
    Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
    NOTE:
    • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
    • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
    1. Press the button(View Images) button to check that the picture is played back in the LCD. If no picture appears in the playback mode, it might be a malfunction of the LCD.
    2. Check the following.
      NOTE: Depending on the models, some items below may not be applicable.
      • Ensure the lens cap on the front of the camcorder has been removed.
      • Ensure the lens cover is open.
      • Ensure the STANDBY/LOCK switch is set to the STANDBY position.
      • Turn on the camcorder and set it to the CAMERA mode.
    3. Ensure a fully-charged battery is inserted in the camcorder.
    4. Adjust the brightness setting of the LCD screen.
      NOTE: It may be difficult to see the image if the LCD screen is exposed to the sunlight when recording outdoors. Block the sunlight to check the image.
    5. Look to see if an image can be seen in the viewfinder or LCD.
      IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. If the viewfinder is pulled out, the image may not be displayed on the LCD screen. Check if an image is displayed by retracting the viewfinder. To use the viewfinder, the LCD must be closed.
      NOTE: If images are not displayed on the monitor or viewfinder while recording movies in 4K, check if 4K Output Sel. is set to Memory Card+HDMI.
    6. If the issue is still unresolved, the product may need to be repaired.
