The pictures are blurry when the SteadyShot function is off and the camera is attached to a tripod.
The camera is equipped with a high-resolution image sensor. Due to this reason, images may become blurred even by a slight vibration during shooting.
- To avoid blurry pictures, use a solid tripod and be careful not to extend the legs or elevate more than necessary. It is also recommended to use a large camera platform to increase stability.
- We recommend that you use the remote commander or the self-timer function of the camera.
