Article ID : 00134779 / Last Modified : 21/10/2020Print
    How do I add or remove icons from the camera's LCD display?
    To select which icons you wish to display on the LCD display:
    1. On the camera, press the MENU button.
    2. Select Custom Settings
      Custom Settings Icon
    3. Press the DISP button.
    To remove or prevent icons from showing on the LCD display:
    1. Select the items you do not want to show on the LCD display.
    2. Press the centre of the control wheel to uncheck the selected item.
    3. Repeat steps 4 and 5 until you have unchecked each of the desired items.
      NOTE: At least one item must be checked to save the settings and exit the menu.
    4. Press the MENU button.
    To add icons to the LCD display:
    1. Select the items you want to show on the LCD display.
    2. Press the centre of the control wheel to check the selected item
    3. Repeat steps 4 and 5 until you have checked each of the desired items.
