Article ID : 00065832 / Last Modified : 29/03/2019
Unable to operate Bluetooth speaker
In order to operate the Bluetooth speaker:
  1. Check that the system is turned on.
  2. If the POWER/HOLD switch is set to HOLD, slide it to the centre.
    Power Hold Switch
If you are still unable to operate the Bluetooth speaker, press the RESET button found on the left side of the Bluetooth speaker with a thin object like a small pin.
Reset Pin
If you have followed the steps provided and you are unable to operate the speaker, repair may be required.
