Article ID : 00164460 / Last Modified : 28/11/2016Print
    How to uninstall a program
    Follow this procedure to uninstall a program using the operating system uninstall utility.
    1. Click the Start button and then click Control Panel.
    2. In the Control Panel window, under Programs, click Uninstall a program.
    3. In the Uninstall or change a program window, click to select the program to uninstall, and then in the menu bar, click Uninstall.
      NOTES:
    4. Follow the on-screen instructions to finish uninstalling the application.
      NOTE: If the program does not uninstall properly, reinstall the program , then try uninstalling it again.
    5. Close the Uninstall or change a program window.
