Article ID : 00164362 / Last Modified : 29/03/2019Print
How to use the Application Manager for VAIO software
    IMPORTANT: If all pre-installed Sony applications have been uninstalled, the Application Manager for VAIO software will not be listed in the Uninstall or change a program list.
    1. Click the Start button, then click Control Panel.
    2. In the Control Panel window, click Programs, and then click Programs and Features.
    3. In the Uninstall or change a program window, click to select Application Manager for VAIO and then on the toolbar, click Uninstall. Image
    4. In the Application Manager for VAIO window, click to select the desired program and click the Uninstall button. Image
      IMPORTANT: Multiple applications cannot be uninstalled at the same time using Application Manager for VAIO.
    5. Follow the on-screen instructions to complete the uninstall procedure.
