Article ID : 00065795 / Last Modified : 25/05/2022Print
What is the passcode, or password, for pairing with another Bluetooth device?
    The passcode of your device is set to 0000 (four zero).
    When paring with another Bluetooth device, if the passcode of your device is required on the screen of another Bluetooth device, please enter 0000 (four zero).
    NOTE: Depending on the other Bluetooth device, the passcode may be called Pass key, PIN code, PIN number or Password.
