Article ID : 00157784 / Last Modified : 25/05/2022Print
The Resume Play option is not working on the Blu-ray Disc (BD) player
    The DVD / BD movie or USB file will not remember the place where it was last played if the stop point on the BD player was cancelled.
    A stop point is cancelled when:
    • Changes have been made to the settings on the BD player
    • The BD player has been turned off
    • The STOP button has been pressed twice
    • You open the disc tray of the BD player
    • The content has been changed
    • The USB device has been replaced
    IMPORTANT:
    • The Resume Play option is not operable with BD Java (BD-J) movies. Refer to the case or packing material with the movie to determine if it is a BD-J disc. An indicator of BD-J is on the BD cover that says BD Live or Bonus View.
    • Depending on the disc, Resume Play may not be possible.
