IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. If you have an older model that does not connect via USB, the steps that mention USB connection will not apply.
NOTE: Because each of these steps represents a possible solution to this issue, check the device status after completing each step.
Determine which of the following conditions applies to your model, and try the corresponding solution.
| Walkman with a screen | Walkman without a screen |
Solution for Walkman with a screen
Connect the Walkman to a computer or AC power supply, and check the screen of the Walkman.
- The battery indicator is displayed on the screen.
If the indicator is displayed, the battery is charging correctly. Wait until the indicator changes to FULL for the battery to charge completely.
- Nothing is display on the Walkman (the screen of the Walkman is black)
NOTE: If the Walkman has not been used for a long period of time or the battery is almost depleted, nothing may appear on the screen for a while after charging starts. Charge the battery for about 5-10 minutes before you operate the Walkman.
- Check the USB cable or AC power adapter connection.
If you are using a USB cable
- If the computer enters a power saving mode while the player is connected via the USB cable, such as the Sleep or Hibernation mode, the battery will not be charged. Instead, the player will continue to draw power from the battery, discharging it.
- Make sure the USB cable is plugged into the player and the computer securely. Unplug the cable from both ends and plug it back in.
- Connect the Walkman using the supplied USB cable.
- Do not use a USB hub. Connect the Walkman directly.
- If your computer has more than one USB port, try plugging the USB adapter into a different USB port to make sure there is not a problem with the current USB port.
- Try charging with another device to check if there is a problem with your computer.
If you are using an AC power adapter
- If using an AC power adapter, ensure the adapter is securely connected and plugged into a working AC wall outlet.
- Try plugging the AC power adapter into a separate AC wall outlet to make sure there is not a problem with the current AC outlet.
- Connect the Walkman using the supplied cable.
- Try charging with another device to check if there is a problem with your AC adapter.
NOTES:
- Charge the battery in an ambient temperature of between 5 ºC to 35 ºC (41 ºF to 95 ºF). If you try to charge the battery outside of this temperature range, the battery indicator may blink, and charging cannot be performed.
- The number of times a battery can be recharged before it needs to be replaced is approximately 500 times.
- This number may vary slightly, depending on the conditions under which you use the player.If you do not intend to use the player for over six months, charge the battery at least once during this time to maintain battery performance.
- Reset (Reboot) the Walkman
If the problem persists even after you have reset the Walkman, the Walkman or USB cable needs to be inspected and repaired
Solution for Walkman without a screen
Connect the Walkman to a computer or AC power supply, and check the lamp of the Walkman.
- The operation lamp (OPR) is lit up.
The battery is charging correctly. When charging is complete, the lamp will turn off. - The operation lamp is turned off.
If the lamp is turned off, the battery is either fully charged or is not charging. - Check the USB cable or AC power adapter connection.
NOTES:
- This number may vary slightly, depending on the conditions under which you use the player. If you do not intend to use the player for over six months, charge the battery at least once during this time to maintain battery performance.
- If the terminals are not connected to each other properly, the Walkman may not be able to charge. Please make sure to keep the Walkman terminals clean.
For waterproof Walkman model, wet a soft brush such as toothbrush with water and wipe the moisture off, for details check the following video:
- Reset (Reboot) the Walkman. If the problem persists even after you have reset the Walkman, the Walkman or USB cable needs to be inspected and repaired.
