Article ID : 00108064 / Last Modified : 30/03/2021Print
    Why images are displayed upside down on the LCD screen?
    Images are displayed upside down on the LCD screen.
    The display switch may have problems. Turn off the camcorder, remove the battery or the AC adaptor/charger, attach it again about 1 minute later, and turn on the camcorder.
    If the problem persists even if you try the above, the camcorder may need to be repaired.
