Article ID : 00129999 / Last Modified : 25/09/2017
Unable to copy recorded images to an external Hard Disk Drive (HDD) connected to the camcorder.
Only images recorded on the medium selected in Media Select can be copied after an external recording medium, such as an external HDD, is connected to the camcorder. To change the medium that contains the images to be copied:
  1. Go to MENU.
  2. Select Setup.
  3. Select Media Settings.
  4. Select Media Select.
  5. Select the medium where the images are recorded.
NOTE: To import recorded images to a computer or an external HDD connected to your computer using PlayMemories Home, refer to the following.
