How to view movies saved on a computer or a USB external HDD by Direct Copy function on a TV.
To play back movies saved on a computer:
- Connect the camcorder to the computer and write back the movies to the camcorder using the PlayMemories Home software .
NOTE: Only AVCHD, MP4 and XAVC S movies can be written back.
- Connect the camcorder to the TV by HDMI cable.
To play back movies saved on an external recording medium:
(Only for models with the Direct Copy function)
- Connect the camcorder to the external recording medium with the USB cable.
NOTES:
- A VMC-UAM1 USB Adapter Cable (sold separately) is required if a USB Adapter Cable is not supplied with your camcorder.
- Use VMC-UAM2 (sold separately) if your camcorder is equipped with Multi Terminal.
Connect the camcorder to the TV.
Select the Play without copying option.
NOTES:- Supply power to the camcorder using the AC Adaptor.
- Some camcorders may not be compatible with the Play without copying function when connected to an external HDD.
