Article ID : 00075244 / Last Modified : 17/11/2016
A dark shadow appears at the lower left corner of images recorded with a flash
IMPORTANT: This issue does not occur on all models.
Depending on the condition when shooting at the wide end with the built-in flash, the lens shadow projected by the light from the flash may appear in the lower portion of the picture.
To avoid this, try shooting as follows:
  • Move the ZOOM toward the T side and try shooting your subject from a little further away.
  • Set the Flash mode to Off and use the High Sensitivity mode.
