Article ID : 00116106 / Last Modified : 05/05/2015
Unable to connect to the Bluetooth audio device after turning the Bluetooth signal on.
When turned on, the car stereo will automatically try to connect to the last connected handsfree device. This can take up to one minute to process. To avoid this, you can do the following:
IMPORTANT:If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
  1. Turn on the Bluetooth audio system.
  2. Press the SOURCE button repeatedly until BT audio appears in the display.
  3. Press the 6 button until you see the Bluetooth icon flashing. Once a connection has been established with your audio device, the icon will become solid.
NOTE: If Bluetooth connection is not established after following the steps above, perform the connection through the Bluetooth audio device.
