Applicable Model
This information is for the following model(s):
- WH-CH520
Notice Before Updating
Read this section before starting the update.
This update uses the Sony | Sound Connect app. For information on downloading or updating the application, please refer to the Sony | Sound Connect app page, and for the update procedure, please refer to this page.
About This Download
Benefits and Improvements
- Enhances system software security features
Previous Benefits and Improvements
System Requirements
- An Android device (Ver. 10.0 or later) or iPhone (iOS 16.0 or later)
- An active Internet connection
- The latest version of the Sony | Sound Connect app (Ver. 12.4.0 or later) must be installed
- The headset must be connected to your Android device or iPhone
File Info
- Name: Firmware update 1.0.6 for WH-CH520
- Version: 1.0.6
- Size: 857 KB (878 351 bytes)
- Release Date: 05-02-2026
Preparation
Check the Firmware Version
You can check the firmware version as follows:
- Launch the Sony | Sound Connect app.
- Connect your headset to the Sony | Sound Connect app.
- Scroll on app screen and tap Device settings.
- Select System in Device settings menu. This will only appear when the headset is connected to the Sony | Sound Connect app.
- Confirm the firmware version.
Important Notice
- Do not charge the battery or turn off your headset while downloading updates, transferring data, or updating the firmware. Doing so may cause the headset to become unusable.
- Do not perform the update in a location where the Wi-Fi signal is inconsistent or congested, such as on a train or near a microwave, cordless phone, or any other devices that use the 2.4 GHz band frequency radio waves.
- Make sure both devices (Android device or iPhone and headset) are fully charged.
- Disconnect all other Bluetooth devices such as wearable devices or smartwatches from your Android device or iPhone before starting the update.
- When updating the firmware after removing your headset, go to the Automatic Power Off feature in the Sony | Sound Connect app, and select Do not turn off.
- If you select Off when headphones are removed, your headset will automatically turn off after approximately 15 minutes and the data transfer of the update file will be interrupted.
- If that happens, the data transfer will resume the next time your headset turns on and Bluetooth is reconnected. If you change the settings for this update, you can restore the settings after the update is completed.
Before You Upgrade
- Please update to the latest version of the Sony | Sound Connect app (Ver. 12.4.0 or later).
- Once updated, the firmware cannot be reverted to an earlier version.
- The update process will take approximately 5 minutes to complete.
- Depending on the radio wave environment and your Android device or iPhone, the update process may take longer to complete.
Download & Install
To update the headset, follow the procedure below:
- Download the data from the server to the Android device or iPhone.
- Transfer the data from the Android device or iPhone to the headset.
- Complete the update using the headset.
Step 1: Install the Update
- If you have never connected to the Sony | Sound Connect app before, follow the on-screen instructions to set up a connection.
- If you have connected to the Sony | Sound Connect app before, select your headset from the available options.
- The following screen will be shown when the connection has been established. If an update is applicable, the message “The latest audio device software is available” will be displayed. Make sure the headset is connected.
- Verify that Version 1.0.6 is displayed and press START to begin the update.
- Once the download starts, the screen will automatically update after the download is completed.
Note: When the message “Bluetooth Pairing Request” is displayed, press Pair. The update will resume. (Only for iPhone) - The transfer starts. The screen will automatically update after the download is completed. This will take approximately one minute.
Note: Do not charge the battery or turn off your headset while downloading updates, transferring data, or updating the firmware. Doing so may cause the headset to become unusable. If a disconnection message is displayed, wait until the headset automatically reconnect. - When the software update is completed, press OK.
Note: If the screen is not displayed, check whether the version has been upgraded in the following step.
Step 2: Check That the Update Was Successful
After the update, confirm the new version has been installed successfully by following the steps in the Check the Firmware Version section. If the firmware version shown is 1.0.6, the upgrade was successful.
Questions & Answers
What Should I Do If an Update Error Message Appears?
- Press OK.
- Restart the headset (turn them off, then on again).
- Restart the Sony | Sound Connect app and try the update again.
Even though the update failed during the process, check the firmware version to confirm. If the version shown is 1.0.6, the firmware update was successful. If not, try the update again. For details, check the firmware version from the Sony | Sound Connect app settings or go to the Check the Firmware Version section on this page.
