Article ID : 00345132 / Last Modified : 16/04/2026Print
Where is the serial number on the Truly Wireless headphones
    The serial number on Truly Wireless headphones is a seven-digit number printed on the bottom or inside the lid of the charging case. It is located next to, above, or below the model name (WF-xxxxx) or model number (YYxxxx).
    The 7-digit number is printed to the right of the model name (WF-1000XM4)
    Note: The image is an example using the WF-1000XM4.
