How to connect my Sony Bluetooth Headphones or Earbuds - pairing procedures explained
WF-SP700N, WF-1000X
Step 1. Enter the headphones into pairing mode (make them discoverable)
- Place the headphones into the charging case.
- Remove the left unit from the charging case.
- Press and hold the button on the left unit for at least 7 seconds. The indicator flashes blue and red alternately. If you put on the headphones, you will hear a notification sound and the voice guidance saying Bluetooth pairing from the left unit.
Note: If the pairing is not finished within 5 minutes, the pairing mode on the headphones is canceled. If this happens, place the headphones into the charging case again and start the operation from the beginning.
Step 2. Complete the Bluetooth connection on your source device (e.g. smartphone)
- Access the Bluetooth settings of the device you want to connect your headphones to.
- There should be an option to "Scan" or "Search for Devices". This starts a scan for nearby detectable Bluetooth devices.
- If your Sony headphones are in "pairing mode", it will show up in the list of available devices.
- Select your headphones and the Bluetooth connection will be established.
You can check more detailed information for following source devices:
- Walkman
- Android device (smartphone, tablet)
- iOS device (iPhone, iPad, Apple Watch)
- Windows 11, 10, 8.1
- Windows 7
- Mac
- Sony Android TVs (Step 2: Pair the headphones with the TV section)
Note: Not all Sony Android TVs can be used with Bluetooth headphones or speakers. Verify your TV supports Bluetooth using the article Can I use Bluetooth headphones, speakers, and soundbars with my Android TV or Google TV?
If the issue is not resolved
If the issue is still not resolved, refer to the article Tips on pairing Bluetooth headphones and other devices.
