Article ID : 00366075 / Last Modified : 03/09/2025Print
An echo sound is heard when wearing the LinkBuds Fit earbuds
    When using the earbuds' Noise Canceling function or Ambient Sound mode, an echo sound may be heard in the following situations. This is normal and not a malfunction.
    • When you touch the earbuds' microphone (A) or bring your finger close to it
      "A" is located on the surface of the headphones housing unit
    • When you cover your ear with your hand over the earbuds
    • When you adjust the position of the earbuds in a noisy environment by pressing them firmly against your ears
    Hint: When putting on or adjusting the position of the earbuds, hold them lightly to avoid touching the microphone, and do not cover the earbuds with your hands or other objects. This can help reduce the echo sound.
