Before you start
If you have paired the headphones with multiple devices before and can no longer connect with one of those devices, refer to this article: The headphones or speaker cannot connect with a desired device when I have paired with multiple devices.
Solution
Follow these steps to troubleshoot the issue:
Note: The following procedure use LinkBuds Open images for reference.
Check the status of the indicator when you place both earbuds (left and right) in the charging case and open/close the lid.
- The indicator lights up in green or orange
The headphones are fully charged. Go to the next troubleshooting step.- The indicator repeatedly flashes in orange and blue when the lid is opened
The software update is in progress. Wait until the update is complete.- The indicator does not light up
The remaining battery of the headphones is 1% or lower. Charge the headphones and, after charging is complete, try the pairing again.
Note: If foreign matter, sweat, or moisture is left on the charging port of the earbuds or the charging case, the charging function may be affected or not be possible at all. Gently clean the charging ports using a dry, soft cloth or a cotton swab. For details, refer to this article: LinkBuds Clip (WF-LC900) | Cleaning your earbuds and charging case.
- Try the following procedure, and check if the pairing can be done successfully.
- Restart the device you are trying to pair.
- Delete the Bluetooth device information of your playback device.
For details on how to delete the Bluetooth device information, refer to this article: How to delete the Bluetooth device information of your playback device. - Perform the pairing again.
Refer to the appropriate article: LinkBuds Clip LinkBuds Open
- The pairing can be successfully completed.
- There seems to have been an issue connecting with the device, such as Bluetooth pairing being disconnected.
- The pairing fails.
- Go to the next troubleshooting step.
If you have a different smartphone, Walkman, or other device, try to perform a Bluetooth pairing with the headphones and one of these other devices:
For devices that have been connected with LE Audio in the past, turn off the Bluetooth setting:
If there are any devices that have ever connected with LE Audio, the headphones may automatically connect with the device when the headphones enter the pairing mode. If this is the case, turn off the Bluetooth setting on the connected device, and perform pairing with another device.
- Pairing can be done successfully
- The headphones were connected to another device.
- Pairing fails
Reset (restart) the headphones.
Refer to the Help Guide or view the How to reset video:
If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
- The pairing can be done successfully.
- The issue may have been caused by a temporary malfunction of the headphones.
- Initialize the headphones, and then try the pairing again.
Initialize the headphones.
Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to reset video:
- Perform pairing again.
Note: If the headphones are not displayed in the connected device, remove the headphones from the charging case once, then the headphones will enter pairing mode again and will appear in the device.
- The headphones may have malfunctioned, and service may be required.
