What do I need to check before buying headphones or earbuds?
Choosing the right headphones or earbuds is about more than sound quality. Your daily routine, listening environment, comfort preferences, call needs, gaming setup, and device compatibility can all influence which model is the best fit for you.
In this guide, we’ll walk through the most important things to consider before purchasing Sony headphones or earbuds and help you better understand which features may suit your lifestyle.
Meet the Sony headphone and earbud families
One of the first questions when buying headphones or earbuds is: Which type of product best suits my lifestyle and listening habits?
Sony offers several headphone and earbud families designed for different situations, from commuting and travel to gaming and staying aware of your surroundings.
WH Series
Product type: Over-ear wireless headphones
Often suited for: Travel, entertainment, working from home, long listening sessions
Key benefits: Comfort, immersive sound, strong Noise Canceling
WF Series
Product type: True wireless earbuds
Often suited for: Commuting, workouts, everyday listening, portability
Key benefits: Compact size, charging case, lightweight design, Noise Canceling
LinkBuds
Product type: Open-style, awareness-focused, or Noise Canceling earbuds
Often suited for: Walking, offices, shared spaces, staying aware of your surroundings
Key benefits: Lets in ambient sound while listening, with Noise Canceling available on selected models
INZONE
Product type: Gaming headsets and true wireless gaming earbuds
Often suited for: Gaming, multiplayer communication, streaming, portable gaming
Key benefits: Immersive gaming audio, voice communication features, long-session comfort, Noise Canceling
Which Sony headphones or earbuds profile sounds most like you?
Select the option below that best matches your listening habits.
WH Series headphones
Over-ear comfort, strong Noise Canceling, and longer battery life for travel and commuting.
WF Series earbuds
Compact and portable earbuds designed for commuting, travel, and everyday movement.
A great match for you: Noise-canceling headphones or earbuds
Noise Canceling can help reduce background noise from trains, planes, traffic, or busy places.
- Look for strong Noise Canceling performance
- Check battery life for longer journeys
- Choose over-ear headphones if long-wear comfort is important
A great match for you: INZONE gaming headsets and earbuds
Sony's INZONE range includes both gaming headsets and true wireless gaming earbuds, designed for immersive gaming, team communication, and long play sessions on PC and PlayStation.
- Choose an over-ear headset for maximum comfort and communication during long sessions
- Choose gaming earbuds for a lighter, more portable option
- Look for low-latency wireless or wired connection options
- Check microphone quality for multiplayer communication
Comfortable over-ear models designed for long meetings, calls, and work sessions.
WF Series earbuds
Compact earbuds with microphone and multipoint features for flexible everyday use.
A great match for you: Models with microphone features and multipoint connection
Multipoint connection can make it easier to switch between your phone and computer, while microphone features help keep your voice clear during calls.
- Check microphone and call quality features
- Look for multipoint connection
- Choose a comfortable design for long meetings
A great match for you: Over-ear headphones with immersive audio features
Over-ear headphones can provide a fuller, more cinematic listening experience, especially for long viewing sessions.
Sony’s WH Series headphones are often preferred for immersive entertainment and long listening sessions.
- Look for immersive audio features such as 360 Reality Audio
- Check comfort for long sessions
- Choose over-ear headphones if you prefer a more enclosed listening experience
WF Series earbuds
Compact wireless earbuds suitable for workouts, commuting, and portability.
LinkBuds
Lightweight earbuds designed for movement and awareness of your surroundings.
A great match for you: Lightweight wireless earbuds with water resistance
For workouts, secure fit and resistance to sweat or splashes are usually more important than maximum battery life.
- Check the water resistance rating
- Choose earbuds with a stable and comfortable fit
- Make sure the charging case is easy to carry
A great match for you: True wireless earbuds
Earbuds are small, portable, and convenient for everyday listening, commuting, quick calls, and carrying in a pocket or bag.
Sony’s compact WF Series earbuds are designed for portable everyday listening.
- Check charging case battery life
- Look for comfort and ear tip options
- Consider models with quick charging
LinkBuds
Designed to help you stay connected to your surroundings while listening.
WF Series earbuds
Selected WF Series models include Ambient Sound Mode for greater awareness.
A great match for you: LinkBuds or models with Ambient Sound Mode
These options help you hear people, traffic, announcements, or your surroundings while listening.
- Look for Ambient Sound Mode
- Consider open-style earbuds if awareness is your priority
- Useful for walking, office use, or shared spaces
Think about where and how you will use them
Travel and commuting
Noise Canceling can help reduce background noise on trains, planes, buses, or busy streets.
Office or working from home
Comfort, microphone quality, and multipoint connection can be important for calls and switching between devices.
Gaming
Gaming headsets may provide lower latency, clearer communication, and more immersive sound for longer gaming sessions.
Sports and workouts
Lightweight earbuds with water resistance may provide a more secure fit during movement. Always check the IPX rating.
Movies and entertainment
Over-ear headphones can provide a more immersive cinematic experience, especially for longer viewing sessions.
Outdoor awareness
Products such as LinkBuds or models with Ambient Sound Mode can help you hear people, traffic, or announcements.
Comfort and fit
Comfort can be just as important as sound quality, especially if you wear headphones or earbuds for several hours a day.
Over-ear headphones
Often preferred for long listening sessions, travel, working from home, movies, and gaming.
Earbuds
Compact and portable, making them easy to carry throughout the day. Fit and comfort can vary between users.
TIP: If you regularly listen for several hours at a time, comfort may be one of the most important factors when choosing a model.
Features to check before buying
Noise Canceling
Helps reduce background noise from airplanes, traffic, offices, and other busy environments.
Ambient Sound Mode
Allows you to hear announcements, conversations, or your surroundings without removing your headphones or earbuds.
Battery life
Battery life can vary depending on product type, volume level, and features such as Noise Canceling.
Water resistance
Useful if you plan to use earbuds or headphones during workouts or outdoors. Always check the product specifications.
Allows compatible headphones or earbuds to connect to two Bluetooth devices at the same time.
Low latency
Can help reduce audio delay during gaming or video playback.
IMPORTANT: Water resistance does not mean waterproof unless this is specifically stated in the product specifications.
Connectivity and compatibility
Most Sony headphones and earbuds support Bluetooth connections, but available features may vary depending on your device and model.
Before buying, consider:
- Which devices will I connect to?
- Will I switch between a phone, tablet, or computer?
- Will I use them for calls, gaming, or entertainment?
- Do I need a wired option or low-latency setup?
Many Sony headphones and earbuds support multipoint connection, allowing simultaneous connection to two Bluetooth devices.
For example:
- A smartphone and laptop
- A tablet and smartphone
This can make it easier to switch between calls, meetings, music, and video playback.
Sony audio features and customization
Depending on the model, Sony headphones and earbuds may support features such as:
- 360 Reality Audio creates a more immersive listening experience by placing instruments and vocals around you, almost like being surrounded by speakers at a live concert.
- LDAC is a high-quality Bluetooth audio technology that can transmit more audio data than standard Bluetooth codecs for clearer and more detailed wireless sound.
- Adaptive Sound Control automatically adjusts headphone settings based on your activity or location, such as reducing noise while travelling or allowing more ambient sound while walking.
- DSEE (Digital Sound Enhancement Engine) improves the quality of compressed digital audio files by restoring detail and richness that can be lost during compression.
- Custom EQ settings let you adjust sound frequencies to match your personal preferences, such as increasing bass or making vocals clearer.
Sony | Sound Connect app
Many Sony headphones and earbuds support the Sony | Sound Connect app.
The app allows you to:
- Adjust EQ settings
- Configure Noise Canceling and Ambient Sound settings
- Customize controls
- Update software
- Configure multipoint connection
Get started with the Sony Sound Connect app here!
Final things to check before buying
Before making your purchase, consider the following questions:
- Will I mainly use them at home, outdoors, at work, while traveling, or for gaming?
- Do I prefer portability or longer battery life?
- Do I need Noise Canceling?
- Do I need to hear my surroundings while listening?
- Will I use them for calls, gaming, or online meetings?
- Will I use them during workouts or sports?
- Do I need multipoint connection?
- Will they be comfortable for long listening sessions?
The best headphones or earbuds are not simply the ones with the most features, but the ones that best fit your daily habits, listening preferences, and devices.
