Article ID : 00109945 / Last Modified : 01/12/2023Print
How to connect my Sony Bluetooth Headphones or Earbuds - pairing procedures explained
    WF-C700N
    Select another model
    Step 1. Enter the headphones into pairing mode (make them discoverable)
    • When you pair the headphones with a device for the first time or after initializing, the headphones automatically enter pairing mode when you put them on. You will hear a notification sound and the voice guidance saying Pairing from both units.
    • To pair the headphones with a second device:
      1. Place the headphones into the charging case.
        Note: Leave the lid of the charging case open.
      2. While the lid of the charging case is open, press and hold the pairing button for at least 5 seconds. The indicator on the charging case flashes blue twice in a row and the headphones enter pairing mode. If you put on the headphones, you will hear a notification sound and the voice guidance saying Pairing from both units.
      Note: If the pairing is not finished within 5 minutes, the pairing mode on the headphones is canceled. If this happens, place the headphones into the charging case again and start the operation from the beginning.
    Step 2. Complete the Bluetooth connection on your source device (e.g. smartphone)
    1. Access the Bluetooth settings of the device you want to connect your headphones to.
    2. There should be an option to "Scan" or "Search for Devices". This starts a scan for nearby detectable Bluetooth devices.
    3. If your Sony headphones are in "pairing mode", it will show up in the list of available devices.
    4. Select your headphones and the Bluetooth connection will be established.
    You can check more detailed information for following source devices:
    Note: Not all Sony Android TVs can be used with Bluetooth headphones or speakers. Verify your TV supports Bluetooth using the article Can I use Bluetooth headphones, speakers, and soundbars with my Android TV or Google TV?
    If the issue is not resolved
    If the issue is still not resolved, refer to the article Tips on pairing Bluetooth headphones and other devices.
