Article ID : 00348671 / Last Modified : 06/11/2024Print
How to reset or initialize the Wireless Headphones (INZONE H5 (WH-G500))
    Resetting the headphones
    If the headset cannot be turned on or cannot be operated even when it is turned on, reset the headset.
    Note: Resetting will not delete any data or pairing information.
    1. Connect the headset to an AC outlet.
      Use the supplied USB Type-C cable and a commercially available USB AC adaptor.
      The charging indicator (orange) lights up.
      Illustration indicating the USB AC adaptor (A)
      A: USB AC adaptor
    2. Press and hold the  (power) button and the CHAT button for about 5 seconds.
      After the charging indicator (orange) turns off, release the  (power) button and the CHAT button.
      The headset will be reset.
    Initializing / Reformatting the headphones to restore factory settings
    Notes:
    • The configurations of various settings are reset to the factory preset values.
    • Bluetooth pairing information is deleted.
    1. Turn off the headset.
      Remove the USB Type-C cable.
    2. Press and hold the  (power) button and the CHAT button for about 10 seconds.
      When initializing is complete, the  (power) indicator (white) flashes 4 times.
