Article ID : 00378379 / Last Modified : 25/02/2026Print
Music playback does not stop or the headphones do not automatically power off after removing the earbuds (WF-1000XM6)
    If the IR sensor is dirty, music playback may not stop when you remove the earbuds from your ears, or the Automatic Power Off function may not work properly.
    Clean the IR sensor using a soft, dry cloth.
    Image indicating the location of the IR sensor
    * The IR sensor is located near the charging port on each earbud.
