Sound skips when using the WF-1000XM4 headphones
Follow these steps to troubleshoot the issue:
Before you start
- Update the headphones' software to the latest version. This may resolve the issue. Perform the update before proceeding.
- Using the headphones in a crowded place such as on a train or busy road, nearby devices may interrupt Bluetooth communication and cause sound interruptions, interference, or noise. If the issue does not occur at home or somewhere with fewer nearby devices, then it is Bluetooth communication interference causing the issue, and not headphones.
Solution
- Switch the sound quality mode to Priority on Stable Connection.
- Open the Sony | Headphones Connect app, and connect the headphones and the device via Bluetooth.
- In the Sound tab, set the Bluetooth Connection Quality to Priority on Stable Connection.
Note: If you play music using the LDAC codec, set the Bluetooth Connection Quality to Priority on Sound Quality. If the music source device has the Wireless Playback Quality to LDAC - Connection Preferred setting option, use that setting to stabilize the connection. Depending on the Bluetooth device, you may not be able to change the settings. Refer to the Bluetooth device manual for details on how to change the settings.
- The issue is resolved
- The headphones setting was the cause of the issue.
- The issue is not resolved
- Go to the next troubleshooting step.
Turn off the Adaptive Sound Control function.
When the Adaptive Sound Control is On, the notification sound (beep) tells you when the Noise Canceling or Ambient Sound Control setting changes. This may make you feel that the sound from the headphones is interrupted.
Note: To disable the notification sound, open the Sony | Headphones Connect app and, in the Adaptive Sound Control screen, turn off Notification Tone When Switching.Follow these steps to turn off the Adaptive Sound Control function:
- In the Status tab, select the arrow on the right side of the Adaptive Sound Control menu.
- Turn off the Adaptive Sound Control.
- The headphones settings were the cause of the issue.
- Turn off the Speak-to-Chat function.
- Open the Sony | Headphones Connect app, and connect the device via Bluetooth.
- In the Sound tab, turn off the Speak-to-Chat function.
- The headphones setting was the cause of the issue. When the Speak-to-Chat is set to ON, the headphones pause or mute the music being played and captures the voice of the person you are conversing with on the microphones to make it easier to hear. This may make you feel that the sound from the headphones is interrupted.
- Stop the Bluetooth connection to any device other than the headphones.
- The sound can skip when another device (smartwatch etc.) is also connected.
- Close all apps except the one you are currently using.
- The sound can skip when multiple apps are open at one time.
- Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
- The issue may have been caused by a temporary malfunction of the headphones.
Reset the headphones.
Visit the Help Guide or view the How to reset video:
Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Visit the Help Guide or view the How to initialize video:
- The headphones may be malfunctioning, and service may be required.
