Article ID : 00239908 / Last Modified : 19/01/2026Print
Headphones
    Headphones
    Select a Cable type.
    Select a cable type to connect TV and Headphones.
    The connections will differ depending on your TV model and Headphones. Check the connection methods below and choose the method that matches with your TV and Headphones.
