Article ID : 00357525 / Last Modified : 20/01/2026Print
    While on a phone call, I can't hear the other person's voice or they can't hear mine (WF-C700N)
    Follow these steps to troubleshoot this issue:
    1. Select your issue details:
      I cannot hear the other person's voice
      Go to Step 2.
      The other person can't hear my voice
      Go to Step 4.
    2. Check the following on the connected device:
      1. Make sure the earbuds are connected via Bluetooth.
        Note: If a Bluetooth connection is not established, refer to the appropriate article:
      2. Check the Speaker settings on the connected device:
        • For Android: While you are talking, tap the Speaker or Bluetooth icon, and then select WF-C700N Hands-Free.
        • For iPhone: While you are talking, tap the Audio icon, and then select WF-C700N Hands-Free.
        • For computers: While you are talking, right-click the Speaker icon at the right side of the computer screen, open the Sound settings, and then select Headset (WF-C700N Hands-Free) from the drop-down menu of the Speaker setting.
        Note: The settings menu items may vary depending on the connected device.
      3. Turn up the volume on the connected device.
        Note: Make sure the speaker is not muted on the connected device.
      4. Restart the connected device.
        Note: If the connected device is temporarily unstable, a restart may resolve the issue.
      The issue is resolved
      The issue may have been caused by the Bluetooth device settings or a temporary malfunction.
      The issue is not resolved
      • If the connected device is Android 10 or later, or a Windows computer, go to Step 3.
      • For all other devices, go to Step 6.
    3. If the connected device is Android 10 or later, or a Windows computer, check the following settings:
      For Android 10 or later:
      1. Open the Settings menu on your smartphone.
      2. Select Connected devices.
      3. To the right of the earbuds model name, tap the Settings icon.
      4. Set the Call setting to ON.
      For Windows computers:
      The issue may have been caused by the Bluetooth device settings.
      Go to Step 6.
    4. Fit the earbuds firmly to your ears.
      If the earbuds do not fit your ears, the phone call quality may decrease. Here are some important factors to consider:
      • Make sure the earbuds are worn properly
      • Make sure the microphone of the earbuds and your ear are not in contact with each other.
      The size or fit of the earbuds may have caused the issue.
      Go to Step 5.
    5. Check the following on the earbuds or connected device:
      1. Set the earbuds in the charging case, close the lid, wait for a few seconds, and then remove the earbuds again.
      2. Restart the connected device.
      3. Try speaking louder, as the ambient sound may prevent your voice from being heard.
      The issue may have been caused by a temporary malfunction of the earbuds or connected device, or ambient sound.
      Go to Step 6.
    6. Reset the earbuds.
      Refer to the Help Guide or watch the How to reset video below:
      The issue may have been caused by a temporary malfunction of the earbuds.
      Go to the next troubleshooting step.
    7. Initialise the headphones.
      Note: Initialisation returns the earbuds to the factory settings and deletes all Bluetooth pairing information.
    8. If you have a different smartphone, Walkman, or other device, try to perform a Bluetooth pairing with the earbuds and one of these other devices:
      The connected device or app may be the cause. Use a different device or app, or consult the manufacturer of the device or app.
      Turn off other wireless devices or move away from those devices, as wireless interference can cause the issue. If the issue is still not resolved, the earbuds may be malfunctioning and may require service.
    For more information, check out our Headphones Troubleshooting Guide.
