Article ID : 00285171 / Last Modified : 18/02/2026Print
    Headphones Self-Help Center
    No power, Battery, Bluetooth pairing issues, No sound, Sound from only one side, Audio and Noise-Cancelling, Microphone issues, Physical damage, Missing parts
    Please select the topic that is closest to the issue that you are currently having to perform step-by-step troubleshooting.
    If you are facing an issue that is not listed below, you may try to reset/initialize your headphones by referring to How to reset or initialize the Wireless Headphones.
    Alternatively, please enter your query in the search bar on the main Sony support website.
    Hints:
    1. Learn how to improve your headphones durability, or connectivity to other devices with our Getting Started with Sony Bluetooth Headphones guide.
    2. For WF-1000XM4: If you encounter the touch sensor working unexpectedly, please refer to The touch sensor works unexpectedly even though I don't touch it.
    For information on warranty, please select your country / area from Warranty Information page
