Article ID : 00285286 / Last Modified : 20/01/2026Print
    The headphone volume cannot be adjusted. (WF-SP700N)
    Follow these steps to troubleshoot this issue:
    1. Use the Sony | Headphones Connect app to adjust the volume.
      To adjust the volume using the Sony | Headphones Connect app, move the slide bar next to the speaker icon in the Status tab.
      The volume can be adjusted
      You can use the Sony | Headphones Connect app to adjust the volume.
      The volume cannot be adjusted
      Go to the next troubleshooting step.
    2. Adjust the volume on the connected device.
      For details on how to adjust the volume on the connected device, refer to the device manual or support site.
      Note: Depending on the connected device, the volume may not sync with the headphones. If you cannot get the desired volume by adjusting the headphones or device volume only, adjust the volume on both the headphones and the connected device.
      You may need to adjust the volume on the device in some situations.
    3. If the app has the volume settings, try adjusting the volume using those settings.
      The issue may have been caused by the app settings.
    4. Reset the headphones.
      Visit the Help Guide to reset the headphones.
      The issue may have been caused by a temporary malfunction.
    5. Initialize the headphones.
      Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Visit the Help Guide to initialize the headphones.
      The headphones may be malfunctioning, and service may be required.
    Go to the Headphones Troubleshooting Guide
