Article ID : 00285296 / Last Modified : 19/01/2026Print
    Sound skips or noise is heard from the headphones.
    Follow these steps to troubleshoot this issue:
    Before you start
    Update the headphones' software to the latest version. Doing so may resolve the issue. Perform the update before proceeding.
    Solution
    1. Select where the issue occurs:
      The issue occurs only on the Right unit.
      The issue occurs on both units.
      Go to the next troubleshooting step.
    2. Select when the issue occurs:
      The issue occurs in crowded places, but does not occur when I am at home.
      Other Bluetooth devices may interrupt communications from your mobile device.
      The issue occurs when I use the headphones in a quiet place.
    3. Stop the Bluetooth connection to any device other than the headphones.
      The issue is resolved
      Other Bluetooth devices may interrupt communications between your mobile device and your headphones.
      The issue is not resolved
    4. Close all apps except the one you are currently using.
      The sound can skip when multiple apps are open at one time.
    5. Switch the Sound Quality Mode to Priority on Stable Connection.
      Note for WF-XB700: If the connected device is a Walkman or Android smartphone, set the Sound Quality Mode to Priority on stable connection on the connected device. If you can select the audio codec on your device, first try to set it to AAC, and if that is not available, then set it to SBC. Depending on the device, you may not be able to change the settings. Refer to the device manual for details on how to change the settings.
      1. Open the Sony | Headphones Connect app, and connect the headphones and the device via Bluetooth.
      2. In the Sound tab, set the Sound Quality Mode to Priority on Stable Connection.
      The headphones setting was the cause of the issue.
    6. Check if the issue occurs on all music files.
      The issue occurs on all music files.
      The issue occurs on only one or some specific files.
      The issue may have been caused by the file format. High-resolution audio takes up more file capacity because it contains more information. Due to this, it causes a greater burden when using Bluetooth communication. Convert the files to a different file format, such as MP3 or AAC.
    7. If you have a different smartphone, Walkman, or other device, perform a Bluetooth pairing with the headphones and one of the other devices, then check if the issue also occurs on these devices.
      The playback device that was initially connected may be malfunctioning. Consult the manufacturer of the device.
      The headphones may be malfunctioning, and service may be required.
    Go to the Headphones Troubleshooting Guide
