Article ID : 00234051 / Last Modified : 19/01/2026Print
[360] How to optimise apps (360 Reality Audio)
    By performing the [Optimise apps] function, the information gathered when analysing your ear shape, is applied to the 360 Reality Audio-compatible apps (e.g. your music service provider).
    Attention: Before you can Optimise apps, be sure to first complete ear shape analysis.
    For details, refer to How to analyse your ear shape (360 Reality Audio)
    1. Launch the Headphones Connect app and connect your Bluetooth headphones.
    2. Select 360 Reality Audio Setup - Optimise apps - OPTIMISE.
      Screenshot of how to optimise apps using 360 Reality Audio Setup in the Headphones Connect app
    3. When the message [360 Reality Audio is only available from these music server apps] appears, select the application you want to use.
    4. Read the displayed message, and select either [LAUNCH TO OPTIMISE] or [INSTALL AND OPTIMISE].
    When the message [OPTIMISE COMPLETE] appears, the Optimise apps function has been completed.
