Article ID : 00358103 / Last Modified : 29/07/2025Print
    BRAVIA 3: Channel change feels slow? Try this remote control tip
    If your BRAVIA 3 TV takes a long time to switch channels after you press a number on the remote, there's a quick way to speed it up.
    Why does channel switching feel slow on BRAVIA 3 TVs?
    On BRAVIA 3 TVs, when you press a number to change the channel:
    1. The number appears on screen.
    2. The TV waits to see if you enter more digits (for example, channel 205 instead of 2).
    3. If no additional numbers are entered, the TV will switch the channel after a short pause.
    This is different from previous BRAVIA models and may make the TV feel slower when changing channels.
    How to change channels instantly on your BRAVIA 3 TV
    To skip the delay and switch channels right away:
    After pressing the channel number, press the  Enter button in the centre of your remote’s Navigation D-Pad (directional pad).
    This confirms your selection and changes the channel immediately, without waiting for more input.
    Step-by-step example: Faster channel switching
    1. Press 2 on the remote
    2. Press the  Enter button in the centre of the Navigation D-Pad
    3. The TV will change to channel 2 right away
    Summary: Reduce channel change delay on BRAVIA 3
    If your BRAVIA 3 feels slow when changing channels, try this shortcut: press the channel number, then briefly press the Enter button in the centre of the Navigation D-Pad. The channel will switch immediately without delay.
