Article ID : 00411287 / Last Modified : 07/09/2026Print
    I hear cracking or noises when I'm watching TV using the Secondary Audio Program (SAP)
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    SAP is typically used for receiving secondary audio streams in television broadcasting, such as for alternate languages, audio descriptions, or other supplementary audio.
    If you experience this issue, it could be related to the strength of the TV broadcast signal.
    For models released in 2025 or before: Changing the audio setting from Auto SAP to Mono will reduce cracking and noisy sound.
    1. Press the 123/MENU, MENU, or [...] button on the remote control.
    2. Select MTS audio or Audio, then press Enter.
    3. Select Mono to change the audio setting from Auto SAP to Mono.
