Sony TV's supported file systems for external USB storage devices
You can only use USB storage devices formatted with the file systems provided by Windows (FAT - NTFS).
Please find a compatibility overview in the table below. Learn how to find your TV model name.
Overview of supported file systems
| Supported file systems: | NTFS | FAT32 | FAT16 | exFAT |
Sony Android TV / Google TV (Excluding the W800 and X72K series)
| Yes | Yes | Yes | Yes |
Sony Android TV (X72K series)
| Yes | Yes | Yes | No |
Sony Android TV (W800 series)
| Sony non-Android TV (R/WD/WE/XE70/WG6/XG70/X70 series)
| Sony non-Android TV (Excluding R/WD/WE/XE70 series)
How can you check the format of your USB?
- Right-click the USB drive in Windows Explorer.
- Select [Properties].
- Check for [File System] on the General Tab.
