Article ID : 00173506 / Last Modified : 16/01/2026Print
Videos played from USB device are not displaying full screen.
    1. Adjust screen settings (Wide mode, Auto wide, Display resolution).
      • How to set Wide Mode and Auto Wide
        1. Press the HOME button on the remote.
        2. Select Settings.
        3. Select System Settings.
        4. Select Screen.
        5. Select Wide Mode or Auto Wide.
        6. Change the current setting and check if the issue is resolved.
      • How to set (Display) Resolution
        2. Select Settings.
        4. Select Picture.
        5. Select Resolution.
    2. Check the video resolution.
