Article ID : 00106251 / Last Modified : 10/02/2026Print
My TV doesn't output sound through the DIGITAL AUDIO (OPTICAL) OUT port
    Below are some possible causes for this issue:
    • The connected home theater system, audio receiver, or sound bar is not set to properly decode the digital signal.
    • The TV is not tuned to a digital channel.
    • The setting for the Optical digital audio output is disabled. (Only for BRAVIA 8 II (XR80M2), BRAVIA 5 (XR50), BRAVIA 9 (XR90), BRAVIA 8 (XR80), BRAVIA 7 (XR70), and A95L Series.)
    • The optical cable is faulty or not securely connected.
    • The TV may require a system software (firmware) update.
    • The connected third-party sound bar or home theater system may not be compatible with the TV.
    IMPORTANT:
    • The optical port is designed to output sound when the content you are watching contains digital audio (PCM or Dolby Digital technology). This feature is available on select digital broadcasts and streaming video, and is not supported on standard cable or analog stations.
    • If the content does not contain a digital audio signal, then no sound can be heard through this connection. A secondary analog connection can be used to pass the audio signal in this situation. Additionally, sound sent to the TV through an HDMI connection or other input also may not output through the optical port. In this case, the optical port from the source device (Blu-ray Disc Player, DVD player, cable set-top box, or satellite box) should be connected directly to the home theater or stereo system to get the sound.
    Follow the troubleshooting steps below if the optical port does not appear to be working.
    Note: Each of these steps represents a possible solution to no sound being heard from a TV when using an optical connection to a home audio system or sound bar.
    1. Make sure the home theater or stereo system is set to the appropriate input and mode for the optical connection.
    2. Make sure the optical cable is firmly connected to both the TV and the home theater or stereo system.
    3. Try changing the channel on the TV to another digital broadcast.
    4. Only for BRAVIA 8 II (XR80M2), BRAVIA 5 (XR50), BRAVIA 9 (XR90), BRAVIA 8 (XR80), BRAVIA 7 (XR70), and A95L Series: If the setting for the Optical digital audio output is disabled, enable it.
      1. On your TV remote control, press the Quick Settings (spanner or gear) button.
      2. Select SettingsDisplay & SoundAudio outputOptical digital audio output settings.
      3. Enable Optical digital audio output.
    5. Go into the Sound or Speakers menu of the TV and select External Speakers or Audio System.
      IMPORTANT: Some TVs require that the internal speakers be turned off before outputting the audio signal to another device. This step turns off the internal speakers.
    6. For Android TV™ or Google TV™ models, if the audio system is not compatible with Dolby Digital or DTS, perform the following steps:
      1. Open the Settings screen.
      2. The next steps will depend on your TV menu options:
        • Select Display & soundAudio outputAudio system settingsDigital audio outputPCM.
        • Select Display & SoundAudio outputDigital audio outPCM.
        • Select Bravia SettingsDigital audio outPCM.
        • Select SoundDigital audio outPCM.
    7. Make sure the TV has the latest system software update.
    8. Replace the optical cable.
    9. If the issue is still not resolved, disconnect the optical cable and use an analog connection to output the sound from the TV to the audio system.
      Note: If using a source device (such as a cable set-top box, satellite receiver, or DVR) to get the signal to the TV, you may also be able to connect this device to the audio receiver using an optical connection.
      The following image provides an example of this type of connection:
      Connection Diagram of TV, Audio device, and Source device. There is a source device between A and B, and it is connected by a cable C and D.
      1. TV: Video IN
      2. Audio device: Optical IN
      3. Source device: Optical OUT
      4. Source device: Video OUT
    10. Factory reset the TV. For how to perform a factory reset, refer to the following article.
