Try a solution based on the issue you are experiencing:
Note: When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the How to use the Self Diagnostics option article.
1. Blank screen or No display (With/Without audio)
If the screen of your TV is blank and there is no display, please refer to the No picture on the TV screen article for more in-depth troubleshooting steps.
2. Lines on the screen (vertical/horizontal lines, bands)
Press the HOME button on the remote to display the TV menu screen.
When the issue occurs in the Menu screen
Examples:
There may be an issue with your TV. Follow these steps to troubleshoot:
- Restart the TV and check if the issue is resolved.
- For Google TV™ and Android TV™ models: How to restart (reset) a Google TV or Android TV?
- For other TV models: How to perform a power reset on a Sony television.
- When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the How to use the Self Diagnostics option article.
- If the above steps do not help to resolve the symptom, the product may require service.
When the issue occurs on other than the Menu screen
There may be issues with the broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
Notes:
- If this issue only happens to one particular channel or broadcaster, this may be due to the broadcast signal source. Please contact your service provider for further information.
- If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: 9. Basic checkpoints on screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
- Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
- If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
It is recommended to adjust the antenna direction and location. - Try plugging the power cord into a different electrical outlet and/or surge protector.
These symptoms can occur if the electrical outlet is improperly wired or not producing the proper voltage.
If using a surge protector or extension cord, it also could be faulty.
3. Blurred screen (Blurry, Hazy, Dull)
Example:
Note: Images may look like they are trailing or the screen may be dark during use in a cold place. This is not a malfunction and will recover when the temperature rises back to normal.
- For Google TVs and Android TVs: How to restart (reset) a Google TV or Android TV?
- For other TVs: How to perform a power reset on a Sony television.
- If the TV is connected to an active and stable Internet connection, install the latest TV software. Refer to the How to perform a software update article.
- Clean the TV screen. Refer to the How to care the OLED/LCD TV article.
There may be issues with the TV settings, broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
Note: If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: 9. Basic checkpoints on screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
- For TVs with the Motionflow function, select Auto, Custom, Standard or Off. (The available options may differ depending on the model.)
It is recommended to adjust the antenna direction and location. - The quality obtained from DVD discs recorded on home DVD recorders often varies due to different quality settings being used on the recorders.
Picture quality from VHS tapes often appears to be significantly worse than other sources, symptoms often include grainy and watery picture. - If this only happen when watching internet streaming video app (example: YouTube™, Netflix or Amazon Prime), this could be due to the internet speed. Picture quality/resolution when playback from streaming video app will automatically adjust according to your internet speed. If your internet speed is lower than minimum requirement, lower picture resolution will be shown. For details, refer to the Internet streaming video will only play back in standard definition (SD) quality article.
- Reset your TV to the factory defaults:
- For Google TVs and Android TVs: How to reset the Google TV or Android TV to factory settings
- For other TVs: How to reset the television to the original factory settings
4. Double images (Ghost image, Double image)
- Refer to the Picture and video on the TV is displayed doubly article.
5. Abnormal display
- Refer to the article The screen appears to have a cloudy, white shadow or bright spots when there is no input or when viewing very dark scenes.
- If this only happen when watching internet streaming video app (example: YouTube, Netflix or Amazon Prime), this could be due to the internet speed. Picture quality/resolution when playback from streaming video app will automatically adjust according to your internet speed. If your internet speed is lower than minimum requirement, lower picture resolution will be shown. For details, refer to the Internet streaming video will only play back in standard definition (SD) quality article.
6. Contrast issues (Too bright or dark)
If the screen has an issue with Brightness or Contrast, try the following.
- Adjust the TV settings using the following article:
- Reset the TV.
- Perform a software update.
7. Grey screen
If the display turns to grey when watching a TV program, try to perform the following.
- Reset the TV. For details on how to reset, see the FAQ below.
- Update the software of your TV to the latest version. For details, refer to the How to perform a software update article.
8. Odd colours on the screen (Solarization, No color, faded, Intermixing/Spreading of color)
Example:
- Adjust the picture color settings using following article:
- If your TV has a reset function for its picture settings, follow the instructions below to reset the settings.
- Open the
Settings screen. How to access Settings
- If the remote control has a
Quick Settings button:
- On the remote control, press the
(Quick Settings) button.
- Select
Settings.
- If the remote control does not have a
- On the remote control, press the HOME or MENU button.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Display & Sound — Picture — Reset picture settings for XX.
- Select Display & Sound, Picture & Display or Display — Picture or Picture adjustments — Advanced settings — Reset.
- Select Display — Picture — Reset.
- Select System Settings — Picture — Reset.
Note: If your remote control has the Option button, you can reset the settings by pressing the Option button on the remote control — Picture or Picture Mode — Reset.
- Open the
- Turn off the TV and unplug the AC power cord (mains lead).
- Keep the TV unplugged for 2 minutes.
- Plug in the AC power cord (mains lead) and turn on the TV to check its status.
- Open the
- Select
Settings.
- Select
Settings.
- Open the
- Check if the cable is firmly connected to the TV and the connected device and make sure it is not loose.
- Use a spare cable to replace the currently used one and see if the situation will improve.
- Use another input terminal of the TV.
- Connect your device to other input terminals of your TV.
- On the TV's supplied remote control, press the input button to switch to the input method that corresponds to the connected device and check if the situation improves.
- Connect another A/V device to your TV using the same input terminal to check whether the connected A/V device causes the issue.
It is recommended to adjust the antenna direction and location. - Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
The following shows you solutions if you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable.
- Check if the input method of the TV corresponds with the connected device
Check if the TV and the connected device (an Audio/Video device such as a Blu-ray player) are turned on. Press the Input button on the TV's remote control then switch the input method to the one that corresponds with the connected device, and check whether the picture appears on the TV screen. - Check if the cable is firmly connected to the TV and the connected device
There may be a case that audio/video does not output from the TV correctly if the cable connected to the TV and the A/V device gets loose from the terminals. - When you have a spare cable, check whether the connecting cable causes this issue
Replace the currently used cable then check if the situation will improve. - Connect another input terminal of the TV and check whether the input terminal on the TV causes this issue
Connect the cable to another input terminal of the TV. Example: The cable is currently connected to the component 1 input terminal. Connect the cable to the component 2 input terminal instead. Press the Input button on the TV's remote control then switch the input method to the one that corresponds with the input terminal that you connected in step 1, and check whether the picture appears on the TV screen. - Connect another A/V device to the TV and check whether the connected A/V device causes this issue
If you have another A/V device, connect it to the same input terminal of the TV as the original A/V device then check whether the picture appears on the TV screen.
10. Other screen issues
*Amazon is a trademark of Amazon.com, Inc. or its affiliates.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
