Article ID : 00408332 / Last Modified : 28/07/2026Print
    The built-in microphone doesn't seem to work and the TV fails to react when I say OK Google.
    IMPORTANT:
    • This article only applies to specific products and/or operating systems. Please check the Applicable Products and Categories section of this article.
    • For BRAVIA 2 II (S20M2), W8L, X64L_X70L_X74L_X75L, X74K_X75K, W8K, X7, W8, X74H_X75H series: The Built-in mic is not available. To use Google Assistant, press the MIC button (or Google Assistant button) on the remote control.
    Try these troubleshooting steps:
    If the issue still happens, try the following:
    1. Perform a power reset.
    2. Turn on the television.
    3. For Google TV: Repeat step 1 (turning the Built-in MIC Switch on the TV body off and then back on). For Android TV: Repeat steps 1-4 (Turning OK Google detection off and then back on).
