Article ID : 00174362 / Last Modified : 16/01/2026Print
The TV screen goes black for 10 minutes after I turn on the TV
    If the Picture reset mode of your OLED TV is set to On at the moment when you unplug your TV power cord, plug it back in, then turn the TV on, the TV screen will go black. This happens because the TV enters standby mode to perform panel calibration. The screen will go back to normal display after about ten minutes once the calibration has completed.
    Set the Picture reset mode to Off if you don't want to run the panel calibration:
    1. Access the Settings screen
      • Use the Quick Settings button (For models released in 2019 or later)
        1. On the remote control, press the Quick Settings button.
        2. Select Settings.
      • Use the HOME button
        1. On the remote control, press the HOME button.
        2. Select Settings.
    2. The next steps depend on your TV menu options:
      • Select SystemRetail mode settingsPicture reset mode.
      • Select Device PreferencesRetail mode settingsPicture reset mode.
      • Select Retail mode settingsPicture reset mode.
    3. Select Off.
