What is the Accessibility Shortcut and how is it used?
IMPORTANT:
Blind or partially sighted? Contact Sony using Be My Eyes. About the Accessibility Shortcut
You can quickly access your favourite accessibility function by pressing and holding the MUTE button on your TV remote control for more than 5 seconds. By default, this opens the TalkBack function.
Note: If your TV displays a Use Accessibility Shortcut? message, press the Enter button to proceed.
Accessibility functions you can set as your preferred shortcut
- TalkBack
- Switch Access
- Text Magnification
- Screen Reader
Note: The accessibility functions you can choose from may differ by model.
How to configure the Accessibility Shortcut
- On the remote control, press the Quick Settings (
or
) button and select
Settings.
- Select System.
- Select Accessibility.
- Select Accessibility shortcut.
- Select Shortcut service.
- Select your preferred accessibility function.
Notes:
- The Accessibility Shortcut option is not available during the initial TV setup.
- When TalkBack is set to ON, you cannot use Edit in Quick Settings.
- For models that support eARC, turning on TalkBack will disable eARC mode.
