Useful settings to reduce power consumption
    Article ID : 00284108 / Last Modified : 20/05/2025Print
    Turn off your TV automatically using the Idle TV power off, Idle TV Standby, or Turn off TV after feature.
    Have you ever fallen asleep with the TV on, or forgotten to turn it off after playing a game? By setting the Idle TV power off, Idle TV Standby, or Turn off TV after feature, the TV will automatically go into standby after a certain period of inactivity. You can prevent forgetting to turn off the power, which leads to power savings.
    Note: The feature name (Idle TV power off, Idle TV Standby, or Turn off TV after) differs depending on the model.
    The setting procedure is as follows:
    Note: This feature may not be equipped, depending on the model.
    1. Open the Settings screen.
    2. The next steps will depend on your TV menu options:
      • Select System Power & EnergyEnergy SaverIdle TV power off or Turn off TV after.
      • Select System Power and EnergyEco Dashboard → Idle TV power off.
      • Select System Power and EnergyIdle TV power off.
      • Select Device Preferences, Power or BRAVIA Settings Power or Eco Idle TV standby
      • Select System Settings or PreferencesEco Idle TV standby.
    3. Choose your desired period of inactivity.
      Note: Available setting period differs depending on the model.
    Note: If you want your TV to turn off after a certain time instead of after a certain period of time, you can use the Sleep timer function. The procedure differs depending on the model, and the following is an example. See your TV's manual or Help Guide for more information.
    1. On the remote control, press the HOME / (HOME) button.
      • Select Apps → Select  Timers & Clock under Your appsSleep timer → Select the desired option.
      • Select (Timers icon) → Sleep timer → Select the desired option.
