Article ID : 00257793 / Last Modified : 20/01/2026Print
Product dimensions for A8H Android TV model series
    These dimensions are approximate values.
    For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position (except A89, A87, A85 series)
    TV dimensions labeled A through G
    (mm)
    Model (KD-)ABCDEFG
    65A81448836100485763326140
    55A81227712100473362326140
    Using a stand: Sound bar position (except A89, A87, A85 series)
    (mm)
    Model KD-)ABCDEFG
    65A81448836107590863323132
    55A81227712107578462323132
    Using a stand: A89, A87, A85 series
    (mm)
    Model (KD-)ABCDEFG
    65A89, 65A87, 65A85144883685586363295130
    55A89, 55A87, 55A85122771285573962295130
    Mounting on a wall
    (mm)
    Model (KD-,)ABCDEF
    65A8, 65A89, 65A87, 65A85
    1448836300300574434
    55A855A89, 55A87, 55A85
    1227712300300464310
    G: M6 holes for wall mount bracket
    *Refer to the instruction manual for screw length information.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors.
    Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
