Article ID : 00251048 / Last Modified : 20/01/2026Print
Screen Reader / Talkback
    IMPORTANT:
    Blind or partially sighted? Contact Sony using Be My Eyes
    The Screen Reader and Talkback functions work by vocalizing the information on the TV screen, such as the program guide and setting screen. In order to use the Screen Reader or Talkback function, you need an active Internet connection.
    The setting of the Screen Reader or Talkback function can be confirmed by the following procedure.
    Note: For W800 series: the Talkback function is supported, but the Screen Reader function is not supported.
    How to activate the Screen Reader or Talkback from the Settings screen
    How to stop the Screen Reader or Talkback from the Settings screen
    Notes:
    • The Screen Reader and Talkback functions are available only for focus points and some texts.
    • The Screen Reader and Talkback functions are available only for some areas and languages.
    • Whether a given app is available with the Screen Reader function depends on the app.
    • As of February 2020, YouTube™ is available with the Screen Reader and Talkback functions. The specification may change without notice.
