Article ID : 00250159 / Last Modified : 05/02/2026Print
Tips and notes for the XBR X850G / X950G / ZG9 / AG9 series TV remote control
    Here are tips and notes regarding the remote control included with some 2019 Android TV™ models.
    2019 Bluetooth TV Remote Control
    Remote control features
    • Most remote controls operate using infrared (IR) communication. To use these remotes, point them towards your TV. The supplied remote can control your TV in any orientation because it uses Bluetooth® communication for all operations except for the power button.
    • If Bluetooth communication is disconnected for whatever reason, the remote control automatically switches to IR mode.
      • The  (MIC) button only works using Bluetooth communication.
    How to pair the remote
