Which soundbars are supported by the A/V Sync setting on my TV?
List of audio systems supported by the A/V sync setting
A/V sync-compatible soundbars
When the A/V sync setting on your TV is set to Auto, A/V sync works with these specific audio systems (connected via HDMI):
- BRAVIA Theatre Bar 7 (HT-A7100)
- BRAVIA Theatre Bar 5 (HT-B500)
- Bravia Theatre 9 (HT-A9000)
- Bravia Theatre 8 (HT-A8000)
- Bravia Theatre Quad (HT-A9M2)
- HT-A9
- HT-A7000
- HT-A5000
- HT-A3000
- HT-G700
- HT-X8500
- HT-XF9000
- HT-ZF9
- TA-AN1000
How to set A/V Sync to Auto
Follow the steps below to set A/V sync to Auto:
- Open the
Settings screen. How to access Settings
- The next steps will depend on your TV menu options:
- Select Display & Sound → Audio output → Audio system settings → A/V sync → Auto.
- Select Display & Sound → Audio out → Audio system settings → A/V sync → Auto.
- Select Display & Sound → Audio output → A/V sync → Auto.
- Select Sound → A/V sync → Auto.
